Get Tip is a command that sets or changes the active probe tip orientation (the A and B angular positions on an indexable or motorized probe head, such as a Renishaw PH10) for subsequent measurement steps.
What the Command Does
When CMM-Manager encounters a Get Tip command during program execution or teaching:
- Rotates the Probe Head: It commands the motorized head to articulate to the designated A and B angle configuration (e.g. A=45° B=90°). For a manually indexable probe head, CMM-Manager prompts the operator to manually rotate to the specified angles.
- Loads Calibration & Offset Data: It updates the software to use the precise 3D center offset vector, stylus ball diameter, and calibration results associated with that specific tip angle.
- Updates Visuals & Status: It changes the 3D graphical display to show the probe rotated at the new angle and updates the Active Tip pane on the bottom Status Bar.
How to Insert a Get Tip Command
When creating a part program in Teach-On Mode:
- Select the Probe tab on the Ribbon Bar, locate the Tip group, and click Get Tip (or click the Get Tip button within an Add Move / Get Tip dialog).
- In the Tip Manager window that pops up, highlight the target calibrated tip angle from the list and click Select. CMM-Manager will perform the probe change at this point. Therefore, ensure that the probe head is positioned away from any obstacles, especially when using a PH10 or other motorized probe head.
- CMM-Manager inserts a Get Tip operation directly into your Program Database.
Alternatively, you could insert a Get Tip command by opening Tip Manager (Ribbon Bar → Probe tab → Tip Manager), highlighting the desired tip, and clicking Select.
Useful Options
Display Queried Tip
Display Queried Tip is a checkbox in Tip Manager that enables a live 3D visual preview of whichever probe tip you currently have highlighted in the tip list. It allows you to visually verify the A and B rotation angles in 3D space before committing to a tip selection.
Auto Close Upon Tip Selection
This option controls whether the Tip Manager dialog box automatically closes after you choose a probe tip.
Prompt for Clear Path
The Prompt for Clear Path option is a safety check box located near the bottom of the Tip Manager window.
When this option is checked, CMM-Manager displays a warning prompt instructing you to move the probe to a safe location before rotating the probe head. This helps ensure that any potential obstacles are cleared before the head articulates, preventing the stylus or probe body from colliding with the part, fixtures, or machine table.
This prompt appears only when teaching a program. Program execution will not be interrupted, even if this option remains enabled.
