Title (Optional - CMM-Manager 2022 or above):
Enter text here to display items such as Balloon numbers or Key Characteristic numbers from the print in the report.
Feature:
- Enter the controlled feature to be reported. All CMM-Manager pick options are available.
Type (Read Only) :
- Type displays the actual feature type since it is not required that the Feature Name contains the feature type as part of the name.
Index:
- Selecting Index allows accessing multiple features of the same name which were created in a VB Script loop. If this option is selected, a numeric input box will be displayed to enter the desired index number of the feature.
Note:
- Enter optional descriptive text to be displayed as a note in the report output.
Tolerance Zone:
- Tolerance - The specified tolerance value obtained from the print.
- Material Condition:
- RFS is selected by default.
- MMC and LMC are enabled only if:
- The controlled feature is a feature of size.
- The size of the controlled feature has been reported prior to this output.
- Datum - The reference feature or a datum plane/axis. All CMM-Manager pick options are available.
Use Current Ref. Frame:
- When this option is selected, the true position of a feature is measured from the current reference frame. Please ensure that the reference frame represents the datum structure specified in the print before reporting.
- Datum Feature #1, #2, and #3 are used to indicate primary, secondary, and tertiary datums on the report. The material conditions can be assigned to datums here; however, size of the datum feature must be reported prior to this operation. If no material modifier is involved, specifying datums is optional.
Create New Ref. Frame:
- A new reference frame for the true position calculation is constructed on the spot. Simply drag-and-drop appropriate features to Datum Feature #1, #2, and #3 then select MMC/LMC if applicable.
Nominal Position:
- The nominal position of the feature can be updated here. The nominal axis vector can be updated as well if the controlled feature is a cylinder.
Reference Length (For Cylinder and Cone):
- This option allows a user to specify the reference length.
- Feature - Use the measured feature's length for the reference length.
- From Middle - The reference length will be specified along the feature's axis and centered about the midpoint of the measured feature. The length will be equal to the value specified in the numeric entry box.
- From Top - Use the top of the measured feature for the top point of the length and extend the length along the axis of the feature by the amount specified in the numeric entry box.
- From Bottom - Use the bottom of the measured feature for the bottom point of the length and extend the length along the axis of the feature by the amount specified in the numeric entry box.
The reference length could be negative, which will turn the direction around (i.e. along inverse of cylinder axis).Below is an example of how these options will affect the measurement:
- A cylinder through a 20mm thick part using Feature will give you the TP over the 20mm of ACTUAL part. OOT will be determined at the worst point top or bottom.
- A cylinder through a 20mm thick part using "From Bottom" and specifying 20mm will give you the same result. OOT will be determined at the worst point top or bottom.
- A cylinder through a 20mm thick part using "From Bottom" and specifying 10mm will give you 1/2 the full result. OOT will be determined at the worst point between the bottom and 10mm above the bottom.
- A cylinder through a 20mm thick part using "From Middel" and specifying 10mm will give you 1/2 the full result. OOT will be determined at the worst point between the MIDDLE and 10mm above the middle.
- A cylinder through a 20mm thick part using "From TOP" and specifying 10mm will give you 1/2 the full result. OOT will be determined at the worst point between the TOP and 10mm ABOVE THE ACTUAL PART.
Coord:
- When enabled, the true position report will include the nominal position of the feature in cartesian coordinate system.
Coord Dev:
- When enabled, the true position report will include the positional deviation of the feature in cartesian coordinate system. This could be useful for adjusting the manufacturing process.
Feature Rpt:
- This is the option to combine the feature report information with the true position report. Once the box is checked, Feature Report tab will appear, and the user can report location, size, and form of the feature. This is a convenient way to output the size of the feature for MMC/LMC.
Show Location Tolerances:
- When this option is enabled along with Feature Report, the feature location in cartesian and polar coordinate systems will affect pass/fail status.
