CMM-Manager | How to create a Form Graphical Report
The form graphical report can be deployed to visually understand the form error of a feature.
To create a form graphical report of a feature, please measure the desired feature first. It is recommended to increase the point density for the graphical report to be effective.
Next, go to the Feature Database, right-click on the measured feature, then select Create Form Graphical Report. The form graphical report will be added to the report database as well as the corresponding form deviation report.
The default report cannot accommodate a graphical report, thus CMM-Manager will automatically create a new report if it doesn't exist already.
If 2D feature, points will be represented as spikes. The length and the color indicate the magnitude and the direction of deviation. The average diameter is calculated by performing the best-fit using all points. The maximum diameter is determined by setting the center to be the same as the average diameter then drawing the circle that will encompass all points. The calculation for the minimum diameter is similar except the circle is drawn in the way that only contains the minimum point.
Maximum and minimum diameters shown in the form graphical report will NOT match diameters obtained from maximum inscribed or minimum circumscribed fitting algorithm due to the mathematical difference. The explanation of these algorithms can be found in our KB article here - https://support.qxcmm.com/portal/en/kb/articles/fitting-algorithms
Utilize Magnify/Demagnify icons in the Ribbon Bar to change the scale of spikes.
