The following attributes can be reported for the indicated feature types.
Feature Reported Characteristics Point Location (XYZ & Polar), 3D Distance, T Distance Line Location (XYZ & Polar), STRT CircleLocation (XYZ & Polar), DIA, RAD, CIR ArcLocation (XYZ & Polar), DIA, RAD, CIR Ellipse Location (XYZ & Polar), DIA_MJ, DIA_MN, CIR Plane Location (XYZ & Polar), FLAT Cylinder Location (XYZ & Polar), DIA, RAD, CYL Cone Location (XYZ & Polar), ANG, CIR, 1/2 ANG Sphere Location (XYZ & Polar), DIA, RAD, CIR Slot Location (XYZ & Polar), LEN, WIDPositional attributes:
- X, Y, and Z - The X, Y, and Z location of the feature in the current Reference Frame.
- R and A(0) - The 2D Radius and Angular location of the feature in the current Reference Frame. This is not the radius of a feature of size, or the angle of a line reducible feature to the coordinate system.
- The 2D view plane is selected by picking an option from the Polar Coord System group.
- 3D and T Deviation - the 3D and T Deviation of points can be reported here. These are the only deviation selections found here.
Size attributes:
- DIA, RAD, DIA_MJ, DIA_MN, ANG, 1/2 ANG, LEN, and WID. The appropriate options will be displayed based on the selected feature(s).
Form attributes:
- STRT (Straightness of a Line), CIR (Circularity of a Circle), FLAT (Flatness of a Plane), and CYL (Cylindricity of a Cylinder). The appropriate options will be displayed based on the selected feature(s).
