Error - "Failed to open (PHC) Com Port"
  1. Verify that the proper COM port drivers are installed and active by checking Windows Device Manager.
  2. Verify that CMM-Manager is attempting to open the correct COM port.
  3. Make sure that a Windows update has not changed COM settings, or more importantly, failed to properly update a driver.  This can be viewed in Windows Device Manager.  There should be no " ! " or " X " indications.
    1. Please note that the COM Port settings (baud, stop, etc) listed in Device Manager are default Windows values that are overridden by the settings in CMM-Manager.  Changing the values in Device Manager does not change the values used by CMM-Manager to open the port.
  4. Please make sure no other recently installed software is attempting to access the same COM port.
  5. Make sure that multiple users are not logged in to the PC, where the non-active user is running a copy of CMM-Manager (or any other software) that would be accessing, and therefore blocking access to the COM port.
  6. If this is a new computer that does not have a(n exposed) COM port, do not assume that there is no on-board COM port.  Sometimes motherboards have an on-board COM port that is enabled, but there is no cable to the outside.  This can easily be mistaken for a USB/Serial or PCI Serial card that the drivers have not installed!  This COM port can usually be turned of in the system BIOS.  Even if not, if you have any problems with devices shown in Windows Device Manager, please resolve those before assuming that the displayed COM port is the one you are looking for!
