This is a pass-through error from the Renishaw UCC Server environment and is not a CMM-Manager error.
This error indicates that there was a problem reading one of the parameters in the machine.ini file. This can be caused by several things.
Locate the file ConfigurationLog.txt and search for "error" or a portion of the actual error text. There will be details indicating what the actual error was. The log file is located at C:\Program Files (x86)\Renishaw\UCC\Machine\**name of your machine**. For UCC Suite versions 5.6 and later, the file will be located at C:\ProgramData\Renishaw\UCC\Machine\**name of your machine**.
Please send the
ConfigurationLog.txt file to
support@qxcmm.com for further evaluation.
A few common causes:
- Installing a version of UCC Suite followed by installing an older version of UCC Suite. This will result in the version number internally in the file being incorrect.
- Edit the machine.ini file and correct the version number manually and re-save.
- Hand editing the machine.ini file. This can result in many kinds of mis-typed keywords, wrong parameter format, incorrect delimiters.
- Correct the errors.
- Corrupted machine.ini file.
- Restore the machine.ini file from a backup.
For further assistance, contact your servicing dealer or Renishaw.
