The Display Window in CMM-Manager is the central 3D graphics workspace where your entire inspection comes to life visually. It gives you a complete, interactive view of your setup, displaying imported 3D CAD models in either shaded or wireframe modes, nominal and measured geometric features, probe hit locations, coordinate frames, and a live 3D representation of your active probe head, stylus, and machine volume.
View Manipulation
Navigating your 3D view is straightforward using standard mouse gestures or the View Toolbar docked along the left edge. You can rotate, pan, zoom, or jump straight to standard perspectives such as top, front, side, or isometric views, oriented to either the machine or part reference frame. You can also organize your workspace with multiple simultaneous viewports—tiling or cascading them across the screen—or use the view tabs along the top to seamlessly flip between different 3D viewing angles and inspection reports.
Mouse Manipulation Setting
To change the 3D mouse view controls in CMM-Manager, head over to the Display tab on the Ribbon Bar, look under the View group, and open Manipulation Settings.
Inside this dialog, the easiest starting point is the Configuration Type dropdown at the top. If you want the controls to behave just like other software you might already use, you can choose from ready-made presets like Default, Unified, Focus, or Camio. If none of those quite feel right or you want to match your favorite CAD software, switching it to Custom unlocks full manual control over every action.
Once in custom mode, you can map out exactly which combination of keyboard keys and mouse buttons will handle rotation, panning, and zooming. For instance, you can set the orbit to your preferred mouse button, adjust whether rotating uses unified orbit, and map panning to a specific key combination like Ctrl or Shift plus a mouse click. You can also configure the scroll wheel behavior by setting the zoom velocity to slow, medium, or fast, and even invert the zoom direction if scrolling feels backward to you.
In addition, if you work with a 3Dconnexion SpaceMouse, there are dedicated settings right in the same window to enable the controller and let it automatically manage the pivot center as you inspect your part. Once everything feels natural, just click OK to apply your setup.
View Port
A View Port is simply your vantage point or camera angle on the 3D graphics screen. It dictates how you look at your CAD model, measured part features, and probe assembly in the virtual workspace. You can access available view ports by right-clicking inside the Display Window.
The software comes ready with ten standard, pre-set viewing angles. These include the six traditional orthogonal views—top, bottom, front, back, left, and right—along with four isometric angles looking in from the front-left, front-right, back-left, or back-right. Depending on the type of machine you are connected to, the system automatically picks a sensible default when you launch: vision and optical systems typically open up looking straight down from the top, while traditional tactile CMMs start you off in an isometric front-left view.
When the standard angles do not quite showcase the detail you need, you can spin, pan, and zoom the model until you find the exact perspective you want, then choose Save User View from the menu. Naming that view pins it directly to your list of available view ports, so you can snap right back to it whenever you return to that inspection step, or clean it up later with the delete option when the project is done.
Another powerful touch is the View Port Option setting located under the Display tab in the Ribbon Bar, which lets you decide whether standard views align to the physical machine axes or to your active part coordinate system. Setting it to the part reference frame is especially helpful when your workpiece is mounted at an angle or held in a canted fixture, ensuring that clicking "Top" or "Front" looks square to the part itself rather than the machine table.n
Background Color
One of its most convenient visual indicators is the background color, which changes automatically depending on your active operation mode. It displays a gray background during quick walk-up checks in Teach-Off mode, turns blue when you are actively teaching and recording program steps, and shifts to green during automated execution in Run mode.
Program Illustration
In Teach-On Mode, the window stays synchronized with your inspection sequence in real time. As you navigate through steps in the Program Database, the display updates immediately to reflect the part's alignment and measurement state up to that exact operation, allowing you to simulate probe motion and verify clearance before executing on the physical machine.
Simulation
When program simulation is initiated, CMM-Manager simulates the probe head's motion in the Display Window. This allows users to verify the intended motion and behavior before running the actual inspection on the machine.
