Sleep Mode should be disabled for any connection used for communicating with a CMM Controller. The most common cases are USB and NIC (ethernet). The following instructions are Windows 10 specific, but other versions of windows are similar.
Disabling Windows sleep and Screen Saver
- Open the Power Options dialog.
- Select the "Change when the computer sleeps" option
- Set the option for "Put the computer to sleep" for "Plugged in" to Never.
- Optional: Set the option for "Turn off display" for "Plugged in" to Never.
- Close the dialogs
Disabling sleep mode for USB, NIC (ethernet)
- Begin by opening Device Manager.
- Proceed to the appropriate USB or NIC (ethernet) instructions.
Open Device Manager:
- In the Windows Search dialog, type "Device Manager".
- A list of options should display.
- Select the option that indicates "Device Manager / Control Panel".
NIC (ethernet):
- Find "Network Adapters" in the list of devices and expand that tree branch.
- Find your hardware network device (there may be more than one), right-click and select properties.
- In the dialog, select "Power Management" and uncheck the box that says "Allow the computer to turn off this device to save power".
- Click OK and then close the dialogs.
USB:
- Find "Universal Serial Bus controllers" in the list of devices expand that tree branch.
- Find the "USB Root Hub..." entry, right-click and select properties.
