The video feed from the Deva camera sometimes appears to freeze, or hang. This is often the result of insufficient power being supplied to the camera via USB. It may be observed that the video becomes unstable at high light settings of the ring light.
- Try a shorter (if possible) USB cable length.
- Be sure to use a high quality USB cable.
- Make sure that the USB cable is plugged into a USB port capable of supplying sufficient current.
- If the USB cable is run through the machine frame, add a powered USB hub near the camera. One of the best locations would be where the Z axis wiring "tank track" joins the bridge axis "tank track".
