The Database Tabs (located within the Database Window docking pane) serve as the main control center for managing your measurement data, generated reports, and inspection program code. By default, these are located on the right-hand side of the CMM-Manager window.
The window is divided into three core tabs: Program Database, Feature Database, and Report Database.
Program Database
Program Database displays your inspection routine as a sequence of automatically numbered operation objects (e.g., 001, 002, 003).
Rather than relying on traditional text-based programming code, CMM-Manager uses task-oriented programming. Each step in the Program Database—such as probe selection, tip changes, alignments, feature measurements, clearance moves, loops, or reporting commands—is stored as an individual object holding all relevant measurement and motion parameters.
The primary purpose of the Program Database is to record, manage, and execute the step-by-step part program. Key functions include:
- Visual Program Structure: Storing the full inspection procedure recorded during Teach-On mode or created offline via CAD.
- Real-Time State Tracking: As you navigate through the program list, the 3D graphics display, reference frames, and measured features update dynamically to reflect the exact state of the program up to the selected step in Teach-On Mode.
- Execution Monitoring: During program execution in Run Mode, it highlights the currently active operation and tracks execution progress step by step.
You can interact directly with the Program Database window to build, refine, and troubleshoot your inspection routines:
- Navigating Program Steps: Clicking on any operation (or using the Up/Down arrow keys) sets it as the active step (highlighted with gray background and red text) and updates the Display Window to match that point in the sequence.
- Reviewing and Modifying Parameters: Double-clicking an operation object re-opens its setup dialog (e.g., measurement strategies, nominal coordinates, hit counts, or path planning) so you can edit parameters without re-teaching.
- Reordering Operations: You can hold Alt key, left-click, then drag-&-drop individual steps or entire groups to resequence execution order.
- Inserting and Deleting Steps: New measurement commands automatically insert directly below the active step. Right-clicking allows you to delete unwanted operations (along with any dependent steps).
- Cutting, Copying, & Pasting: Existing program line(s) can be cut, copied, or pasted by right-clicking the selected line(s).
- Adding Comments and Prompts: You can insert green comment lines (prefaced with $$) and operator prompts.
- Performing Advanced Commands: Additional programming functions can be accessed by right-clicking the desired program line(s).
Feature Database
Feature Database serves as the central repository for storing and managing all geometric features that have been measured, taught, constructed, or defined during an inspection session.
To keep inspection data structured, features in the database are organized into three distinct groups based on the software's active Operation Mode.
- Features - Measure: Contains features created or measured while operating in Teach-Off Mode (used for walk-up measurement and spot checks).
- Features - Teach: Stores features created, taught, or defined while in Teach-On Mode (used during part program creation).
- Features - Run: Stores the actual feature measurement data collected during program execution in Run Mode.
The main purpose of the Feature Database is to store, organize, and provide access to feature geometries and actual data throughout the measurement workflow. It connects the 3D graphical display with downstream operations, enabling features to be referenced for part alignments, constructed geometry, and tolerance reporting.
Typical Tasks Performed in this Window are...
- Reviewing Feature Measurements: Double-clicking any listed feature opens the Feature Data Window, displaying its nominal coordinates, actual measured values, deviations, and individual point data.
- Constructing Features & Generating Reports: You can select and drag features directly from the database into alignment, construction, reporting, and other dialogs.
- Cross-Referencing Graphics: Selecting a feature in the database automatically highlights its corresponding 3D geometry in the Display Window, helping you quickly identify features on the model.
- Renaming Feature: A feature can be renamed by right-clicking the desired feature.
Report Database
The main purpose of the Report Database is to store, organize, build, and customize inspection reports created during a measurement session. It holds the system's Default Report—which is always listed first—as well as any custom text or graphical report templates you define to document measurement results.
Users can interact with the Report Database to perform the following tasks:
- Creating New Reports: Right-clicking the report template root node allows you to create an unlimited number of customized New Reports or New Graphical Reports.
- Configuring Report Properties & Output Formats: Right-clicking a report name opens its Properties dialog. From here, you can set report header metadata (Part Name, Part No., Inspector, Company), define customer data prompts, and configure automatic export formats (such as PDF, MS Excel, HTML, CSV, Data Page, and QC-CALC) along with output folder paths and file overwrite rules.
- Previewing the Report: Double-clicking the Default Report or another custom report opens a preview page, allowing you to review the report visually.
- Open Graphical Report: Double-clicking an existing Graphical Report opens its editing window, allowing you to customize its contents.
