Located in the Advanced group under the Features ribbon tab, the Cross Section Measurement command enables automated, CAD-driven 2D curve and profile inspection. Rather than picking standard prismatic primitives like individual circles or planes, this command intersects a user-defined cutting plane with the 3D CAD model to generate one or more 2D cross-sectional curve segments. CMM-Manager automatically creates a collision-free probe path along these intersecting curves for stitch-type DCC measurement, automatically detecting and skipping across open areas and voids such as cross-holes and slots.
Standard CAD Measure tools are designed for regular geometric shapes such as circles and planes. However, complex components often require inspecting cross-sectional silhouettes across non-prismatic, freeform, or organic profiles. Cross Section Measurement slices through the solid CAD model at specific depths or locations, extracting exact nominal profile contours and normal vectors along the slice.
Use this command when:
- Inspecting sculpted, organic, or freeform surfaces such as turbine blades, aerodynamic foils, chamfered transitions, or molded plastic contours.
- Measuring planar cross-sections where you need to report Profile of a Line or Profile of a Surface across irregular geometries.
- Generating point-cloud slices for best-fit transformation analysis or cloud-to-CAD nominal comparisons.
How to Use Cross Section Measurement
The operation executes in two successive phases: defining the cutting datum plane, followed by configuring the curve segments and motion path.
Phase 1: Define the Base Cutting Plane
Navigate to the Features tab on the main Ribbon Bar, locate the Advanced group, and click Measure Cross Section. The Measure Cross Section dialog opens to establish the datum plane from which all section cuts will be projected. You can define this plane by clicking Pick a Plane and clicking an existing planar face on the CAD model, or by clicking Construct a Plane and manually keying in the through-point coordinates (X, Y, Z) and plane normal vectors (I, J, K). Once defined, CMM-Manager displays the base cutting plane sized to encompass the entire model.
After confirming the base plane, the feature dialog sheet opens to configure the curve generation parameters:
- Section Parameters: Under the Cross Sections group, enter the Depth from Base Plane to set the distance of the first slice from your reference plane, the # of Sections for the total number of parallel slices, the Depth Increment between consecutive slices, and the Point Density to establish point spacing along each curve.
- Generate Curves: Click Create Cross Section. CMM-Manager slices the CAD model at the specified depths and highlights the intersecting curve segments in yellow on the 3D screen. Use the selection buttons (such as Pick Select, Box Select, or Select All) to keep only the specific profile contours you want to inspect.
- Trim and Order Segments: If you need to restrict the measurement boundaries, click Adjust Range - Drag or Adjust Range - Pick Ends to set custom start and end points. You can also click Pick Start Curve and Define Curve Sequences to adjust the order and direction in which the probe traverses multiple curves.
- Save Curve to CAD Model (Optional): Click the Add Sel. to CAD button to permanently save the selected cross-section curve segments directly into the active CAD model as individual curves or polylines. Saving the curve to the model establishes the theoretical nominal geometry required for subsequent Cloud-to-Curve Alignment (under the Alignment tab) and Report Cloud-to-Curve Deviation (under the Report tab).
- Path Planning and Execution: Under Path Planning, select Full Auto to allow CMM-Manager to calculate collision-free transit moves and tip angles automatically, or select other options depending on your measurement preference. Click Create Path to compute the DCC probe path, click Simulate or Verify to visually check clearances, and press OK. The CMM measures the cross-section profile in DCC mode, recording the inspected curve into the Feature Database and adding the operation to the Program Database.
