Create and Edit Calibration Sphere
Before calibrating probe styli, you must define and locate a certified reference sphere in CMM-Manager. Defining the sphere establishes its physical diameter and mounting stem geometry so the software can calculate effective tip sizes and avoid shank collisions. Locating the sphere measures its physical position on the machine table, linking the reference artifact directly to the machine coordinate system.
Accessing the Calibration Sphere Setup
You can access the calibration sphere interface through several quick paths. On the Ribbon Bar, navigate to the Probe tab, locate the Setup group, and click Setup Cal. Sphere. Alternatively, open the Machine Properties dialog by clicking the MORE... pane on the bottom Status Bar or selecting Machine Properties under the System tab, switch to the Cal. Sphere tab, and click the Cal. Sphere Model button.
Defining the Sphere Model
In the Calibration Sphere Model window, click Add to create a new sphere definition, or select an existing sphere and click Edit to open the Calibration Sphere Editor.
Enter a descriptive label in the Name box, such as Def. Cal. Sphere or Master Sphere. In the D field, enter the exact certified master sphere diameter from your calibration certificate. Accurate entry here is critical because CMM-Manager uses this dimension to calculate effective tip diameters; an incorrect diameter will distort probe size calculations or trigger calibration errors.
Enter the stem diameter in the SD field, the overall sphere height in the H field, and define the stem orientation vector under V - Machine R.F. using Cartesian coordinates I, J, K or spherical coordinates. For a standard vertical stem pointing upward along the Z-axis, set I=0, J=0, and K=1. These stem parameters allow CMM-Manager to calculate safe clearance moves and collision-free probe trajectories around the mounting post during automated calibration. Click OK to save the geometry, and optionally click Save to store the setup as an external .SPH file for easy backup and retrieval.
Locating the Sphere on the CMM Table
Once the physical dimensions are saved, you must locate the sphere's actual coordinates on the machine table using a qualified reference tip, typically _RefTip. You must perform this relocation whenever the sphere is physically moved, removed and re-bolted to the table, or when its definition is modified.
Select Locate Cal. Sphere from the Setup group under the Probe tab, or click the Locate Spheres button inside the Calibration Sphere Model window. Select your sphere from the dropdown list, check the DCC Locate Cal. Sphere box for automated measurement, and set the desired number of measurement points.
When prompted, use the jogbox in manual mode to position the probe stylus approximately 10 mm (0.5 in) away from the sphere pointing directly toward its center, then click OK. In DCC mode, CMM-Manager measures the sphere automatically, determines its precise three-dimensional center coordinates in the Machine Reference Frame, and marks the sphere status as located.
Calibrating the reference tip (_RefTip) will automatically locate the calibration sphere.
