If CMM-Manager is not generating a dump file when it crashes, you can configure Windows to create one when the error occurs.
The setup procedure is below:
Windows registry keys must be amended for this process. Adding/modifying/deleting a wrong key may brick Windows OS. Please consult with your IT department if you are not qualified or comfortable with proceeding.
1) Create a folder named LocalDumps in C drive's root location (C:\).
2) Open Registry Editor, navigate to Computer\HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\Windows Error Reporting\LocalDumps key, then add following values to it.
- DumpFolder (string)
- DumpCount (DWORD)
- DumpType (DWORD)
- CustomDumpFlags (DWORD)
3) Assign following string & numbers to these values.
- DumpFolder = C:\LocalDumps
- DumpCount = 10
- DumpType = 2
- CustomDumpFlags = 0
4) Launch CMM-Manager then recreate the crash.
5) Once the software closes, you can navigate to C:\LocalDumps to retrieve the .dmp file.
6) Send this file to QxSoft support team (
support@qxcmm.com). The file can be quite large, thus the file upload link can be provided.
