CMM-Manager cannot see network drives
Certain versions of Windows have policy settings that block applications from "seeing" mapped network drives.  This policy can be changed by adding a registry key to allow access.
Note: If you are not comfortable working with the Windows Registry, please request help from you IT department.  A mistake while editing the registry can disable your PC resulting in loss of programs and/or data.
To configure the EnableLinkedConnections registry value, follow these steps:
1. Click Start, type regedit in the Start Search box, and then press ENTER.
2. Locate, and then right-click the following registry subkey:
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Policies\System
3. Select New, and then click DWORD Value.
4. Type EnableLinkedConnections, and then press ENTER.
5. Right-click EnableLinkedConnections, and then click Modify.
6. In the Value data box, type 1, and then click OK.
7. Exit the Registry Editor, and then restart the computer.
