CMM Accuracy Verification Tools
Introduction
CMM-Manager provides several internal and external tools used to evaluate the performance of your CMM referencing standards such as ASME B89.4.1, ISO 10360, NIST Dimensional Metrology Group (683.01), etc.  The built-in tools can be found in the System Ribbon Tab inside of the Utilities Group.  Other utilities can be downloaded from this KB article - see below.
B89 Repeatability and Ball-Bar Verification
The B89 Ball Bar Test is a test to verify the accuracy of CMM (volumetric) performance while the repeatability test is designed to isolate probing error & repeatability.
ISO 10360-2 Size and Probing Test
The ISO 10360-2 Size Test verifies the volumetric accuracy of CMM while the while the probing test is designed to isolate probing error & repeatability.
ISO 10360-2 Size and Probing Test (CMM-Manager Program)
This VB Script driven CMM-Manager program performs the same test as the built-in ISO 10360 Size Test using a parametric CMM-Manager program.  This program improves the ease of use compared to our built-in utility and provides the user an opportunity to make changes to the program to suit their needs for CMM verification & calibration.
Mitutoyo Step Gauge Verification
This is another CMM-Manager program used to verify length-based standards similar to the above ISO Size tests.  This parametric program is designed to measure and report variations on the Mitutoyo CheckMaster length gages available in various lengths - i.e. 300mm, 450mm, 600mm, etc.
Renishaw MCG - Machine Checking Gage
CMM-Manager's Machine checking gauge (MCG) program is used for monitoring the volumetric measuring performance of your CMM.  The MCG and MCG tools is a powerful reporting tool, not a calibration tool. The greatest benefit of these products is to report the current state of your CMM allowing you to perform preventative maintenance before problems arise.  See the attached native CMM-Manager program and associated MS Excel Spreadsheet from Renishaw used to evaluate measurement results.
