VECTOR DIFFERNCE
VECTOR DIFFERNCE
so when im measuring as points and im showing the xyz and the t value im getting hung up on the fact that my t value is well within my tol of +/-.05mm but the axis location of the point shows off in the less than primary axis of the point. so if im taking a point on a surface that shows a slight vector in all 3 axis (not straight with any axis) i will get almost .1mm difference sometimes in the non check direction, im stumped if im missing a box i need to check to project the point back to cad or where im mixed up but its making things really difficult to make a report that shows good all the way down.
