I read somewhere that you can calibrate specific angles on the PH20 to achieve more accuracy when needed. I think I figured out how to do that by creating another tip with the inferred calibration box un-checked; but now I have two of the same tip angles, one inferred, one standard. How do I make sure CMM-M uses the standard calibrated tip when measuring the feature(s) in question?
