I had to order a 0.5mm tip for a new part we're going to be running. The tip has a slightly different form than standard, as it has to neck down quite a bit. As far as I know, CMM-M only has the 6P stylus editing, Is there a way to add more detail to a stylus configuration, or how would you suggest setting up a tip like this? Also, should I expect any issues qualifying this on a SP25 with a 1.000" master ball? I read something about suggesting qualifying on a smaller (8mm) master ball.
