Hello,
I'd like to hear from users of scanning with the SP25M probe.
I occasionally use this system and I wanted to know if you also have problems measuring.
For example, if I scan a circle with a fairly high point density, it happens that a few points or areas are calculated on the wrong side of the ball.
I've noticed that this phenomenon usually appears on the first parts I measure, as if the system needed to be at the right temperature to be reliable.
