Is there a easier way to input bubbles numbers into CMM Manager?
I currently use the [Item#] format to identify my balloon numbers. i have 28 same size holes to report the diameter, true position, and chamfer size on and it takes a long time to note each tolerance report number for each hole.
For example, [ITEM1.1], [ITEM1.2] .........[ITEM1.28] for 28 Holes.
When i report the features with the thumbtack enabled, it will put [ITEM1] on all features without the decimal point showing which number hole it is.
Thanks
