I think it would be very helpful to have the ability to specify which tip angles auto path planning uses especially when using PH20 as a PH10 with a crank stylus. Auto path planning picks "bad" angles about 25% of the time with this specific setup and it is very time consuming to manually change the paths 25% of the time. I know path planning picks the angles that require the least tip angle changes as possible but that is not always the best angles there have been multiple times when the probe module would have hit the part or got within .01 of the part if I did not manually change the path. I have 9 tip angles calibrated for this probe and I want auto path planning to use only 4 of them when measuring a specific circle.
