I've got a program for a part with a very long seal groove in it. It's square to the table and all done with an A0B0 orientation. Between every point, the auto-path inserts a very long retract, and it really doesn't provide any benefit or clearance.
I realize that I can go in an manually change the path, but there are many operations with several points. Is there a setting that I can change the avoid these retracts?
Thank you!
