Hello,
I've noticed that when you are making a positional report for holes, there seems to be some sort of bug. When you are making reports for multiple holes at the same time and changing the nominals in the "Feature Report" tab, the diameter that I set doesn't carry over to more than the first report. So if I am making a report for 4 holes at one time, I will change the diameter nominal and it only applies to the first report. I have to go in and change the rest manually.
Wasn't sure if there was some setting I missed, or if this could get fixed for the next software update.
Thank you,
Kaleb
