I have a part that I'm checking that has threaded holes and a position call out of .011M that is projected up .600" from top of top plane of where the thread starts. I'm measuring 2 circles in the threaded hole (I did use the thread hole setting and used the pitch of the thread) then I'm extracting raw data points to create point clouds, then I'm constructing a best-fit cylinder. So, now how can I create a projected point that is up .600" from the top of the thread or report on a circle that is projected up .600"? I also need to add MMC bonus of the threaded hole.
I hope this makes sense.
Thank you.
