I am trying to set up a DCC calibration routine with two separate spheres. I am establishing my ref probe on my primary sphere. I then have a command to go over and locate my secondary spear. Following that, I have a multi tip batch calibration set to use my primary sphere with no issue. When I select my secondary sphere in the same multi tip cal, it skips the command without error or execution.
