I have a program where I do a
manual plane
Level,
manual ID
Origin
sync CAD
then move the probe to the location of Datum E and instruct the operator to rotate the part so datum E lines up with the probe.
DCC plane, circle, Datum E
Level, Align, Origin
run time align part
sync CAD
Over time the location where the probe moves to keeps changing and the nominals for E in the program change with it. When I report the location of E and the other holes the nominals reported are correct. The problem is there is an angled hole that should be in the YZ plane but when E is at 4 O'Clock instead of 3Oclock it isn't and the probe angle no longer matches.
Why does this happen and what can I do to prevent it?
