Mirror a Program
Mirror a Program
There wasn't a tab dedicated to praise or things I've found helpful, so hopefully this is ok.
I created a program that revolves around a metal wheel hub, measuring all kinds of planes and diameters every 40 degrees or so, and it utilizes almost 20 angle changes between 2 probes.
I used the mirror program function and it legitimately could not have gone smoother. I didn't have to adjust a single angle or path, outside of a couple "move points", and it saved me an entire day worth of programming. So thank you guys, I'm stoked.
