Hello,
I'm wondering if there is an easier way to measure the distance between two features. I have a part (attached below) that has a dimension, .100+-.003 all around.
I know I can do the distance between for each side and each fillet, but that would mean eight program lines for one dimension. Is there a way to measure this dimension in one reporting feature?
Also, what is T in the type column below? I'm assuming Translation?
Thank you.
