Hey guys,
when aborting CMM Movement, after a Probe Change is initiated (even immediatly after the Command is started and Probe still on the way to the Rack) the Machine Coordinates change. I guess CMM-Manager (or the CMM Controller?) already set the length for the new Probe.. Is this a CMM-Manager thing or something which comes from the Controller? If you start a Program after aborting the Probe Change this could lead to a bad Crash so it would be nice to at least be warned in this Moment if this cannot be prevented otherwise..
Thank you!
