Hi!
What would be the best approach to repeat a program on a fixture with a irregular pattern?
E.g. 17 mm spacing, then 33 mm spacing then 17 mm again and so on.
We´ve looked into batch run, but it seems to work best in a regular grid?
I´ve attached a image to desciribe the layout of the fixture.
As we are transferring the results to our SPC system, we can´t have any index after the feaure name (e.g. Ø5 (1) ) and therefore we would need the report to be saved to disk for each run before the next run starts.
Any suggestions would be appreciated.
Thanks,
