I am having an issue checking a part where the datum surface has a .001 low point on the surface. When I create a plane it is averaging the plane and it throws the parallelism out. When checked on the rock, it is fine because it is sitting on the high points of the surface. Does anyone have a good solution to create a plane from the highest points?
