When creating a uniform hole pattern and using transform, is there any way to include reporting the true position of the feature and having the nominals applied to the corresponding hole so I don't have to report each feature separately after the hole pattern is created?
When I try to transform a feature and report it's true position, the true position report references only back to the original "master" hole and doesn't apply to the hole built by the transform command.
