As a user, I want to generate vision AF measurement locations on CAD surfaces with complex inner and outer boundaries so that I can speed up programming time when using vision AF tools.
Currently, it can be cumbersome to program vision AF (surface) measurement locations on CAD surfaces because the only option is to program them manually or use the "Target Point #" generation method. Adding the "Along Edge" generation method could really help!
