Hello all,
I have a problem that I can't seem to figure out with the feature report. I've attached a photo showing the issue. I'm trying to report multiple points that I have taken in my program to verify where my part could be bowed in or out of tolerance. The issue is that the report isn't applying the tolerance correctly in the Y direction. I should have a high of 1.88580 and low of 1.87409. I would expect this to show me out of tolerance by .00010 and instead it says I'm out by .0041? Seems to only do this in the negative directions? Is there a setting that I have missed or another way to produce a report for each point other than the feature report? Any help would be very much appreciated. Thanks!
