Is it possible to edit a group of CAD measured features at once. For example say I have 100 identical cone measures I have programed but realize it may measure better with the boundaries spread between the two levels it takes points at. Usually something like this when originally creating the program we would translate the cone if we have a pattern to follow, but when you need to edit each individual cone created it can be very time consuming unless there is a way to copy the parameters from one and paste it into all the others, essentially only editing once.
