I am using a plane circle circle alignment, with a 2mm ruby. One of my alignment holes is .130, I went into program settings and changed the back off distance to .020
I ran through the program no problem. I also have the .130 back off distance under DCC overwrite at .020 and it measures no problem in the program. What I ran into is once the program is over, I can't do the same plane circle circle alignment with out opening the .130 box and clicking ok under DCC overwrite. I am not changing anything in there, just opening and closing the box. What would make it do that / what am i missing?
