Hi there, I'm curious if anyone has worked in depth the new feature labels and exporting the report as such.
I have two very large programs that I carefully labeled each report item as a balloon number.
The first program measures the top of the part.
TOP Program: The balloons might go 1,2,4,8.1,8.1,9.1,9.2, 9.3, 43,349, 417 ect.
Bottom Program: 3,4,5,6,7,10,>42>44>348,350>416,418
I'd like to report in the following method so I can get the data into my Excel FAI Report:
Row 1 - (Name of report item) 1, Nominal, Actual, Deviation
Row 2 - (Name of report item) 2, Nominal, Actual, Deviation
Row 418 - (Name of report item) 418, Nominal, Actual, Deviation
Support says this isn't available quite yet. I'm wonding if I can make a few DDE sheets and move the data around. I tried data page+ but it leaves the commas in and doesn't export the report label. 1,2,418 ect. Messy.
Should be a simple way to get the report name and the data out. I can't play with it right now because I'm running the last part... about 2 hours a program and I'd like to finish this project today.
Even if I could get the data out cleanly in rows as numbers, that would probably help speed this up! I have about 2000 recordings to enter.
Thought I'd ask here. Thanks for anything clever!
Tyson K.
