1a) When constructing a plane is it safe to assume the plane constructed from 2 points or 2 circles is normal to the line drawn between those 2 points or circles?
1b) Is the plane center directly between these features?
2a) When constructing a plane between 2 other planes (referenced planes) is the constructed plane parallel to the reference planes?
2b) What if the 2 reference planes are not parallel to each other? If this construction is possible, would the constructed plane be the result of the average of the 2 angles of the referenced planes?
Best Regards,
Cody
