Hey guys,
as I'm revising the German translation I have to switch language while programming.. And I had the case where I could not load a program created on one language. The CMM-Manager Application crashes when loading the Program. If I switch the language again, the program loads successfully. Couldn't repoduce this with a small program with only one construction command, so I guess it is some command causing this problem..
Thank you!
