Afternoon all,
I just made the jump up to the 2022 release and I noticed something different that wasn't mentioned in the notes. There seems to be a change to how the transform function works going from 2021 to 2022. In previous versions you could right click and select all, then right click and transform in order to move both the CAD and the measurements/movement and it would either translate or rotate everything. Now it looks like selecting all no longer allows you to select transform. It appears that it will no longer accept the transformation of the first two lines in the program. With the first two lines deselected you are able to transform the rest of the program, but it now will only move the points of measurement and not the CAD. Was this an intended change in functionality and if so, what is the easiest way to manipulate both the part and measurements? I did look in the help section and did not see any changes in verbiage from 2021 to 2022.
Thanks
