I have a cylinder that when machined comes out as a slight cone. I am interested in reporting on a best fit cone (distance between other features, feature itself for cone angle, etc reports). I measure this cylinder, then extract the points, then I make a point from each point in the cloud from the construct feature>point. So I have a set of many points, and then want to best fit a cone to those points. I am getting an error though 'internal calculation error'. which this likely makes sense as fitting a cone to a perfect cylinder would result in some unknowns. What is the best way to go about setting this up when programming offline, and to be used on a batch of parts. I thought, maybe I will add a point and give it some deviation from the cad perfect cylinder, whats the best way around this issue?
