Many times I have multiple features like holes, tabs, etc.... that have size, angle, distance or position call outs on the drawings.
I report each, but on our in-process inspection sheet that I have to fill out by hand, there is just one space per part for each of the multiple features. Management says I can write down the average of the "group" of features.
I have been creating VB scripts to add up the values and divide by the number of features, then report the result after the last of the "group". Sometimes it gets to be a pain to write the script as the features are not named with a number postscript. ( have unique names) or different 3D, XY, YZ, ZX, AX, AY, AZ
I could see where a reporting option (button) where you could select from the Feature Tree all the features you want to average some value of, then you could select the value type ( dIA, RAD, XY, DIA, etc...) and maybe allow for some flexibility like XY instead of YA for specific individual features (list with check-boxes for your feature selections maybe ??) then the function would report Average and maybe a max/min option as well.
